Help Please! No Climate Control Display
  • Thread starter Thread starter TooTall
T
TooTall
I have a problem with the display on my Climate Control unit. All of a sudden it just goes off. AC and Heat work fine just no display. Anyone know if this could be a fuse problem? And if so where the fuse would be? By the way, strangely the Oil pressure sensor had just failed a few days ago.
New info here the LED is not gone just very faint, cannot see in daylight. I checked the dimmer switch and it's turned all the way up. Battery is an Optima Red Top (1 year old)
Same thing happened to me. Everything worked but no display. I had to get it replaced at the dealer. I took out an extended warranty so it was covered...
Check out the thread in this forum dated 2-23-04
Good luck!
the displays fail all the time.....I've changed mine b4 ................
More New Info -
LED Faint but I can read it when outside light is low.
Checked the DIC codes and came up with these:
A0-LCDM
B2282 Battery # 1 Fault
B2284 Battery # 2 Fault
U1064 Loss of Communications with BCM
A1-LCDM
B2283 Battery # 1 Fault
B2285 Battery # 2 Fault
No other codes come up.
Anyone know if this might lead me somewhere?
Same thing on my 98. Did some diagnosis on it as I was a Chevy tech a long time ago but remember the basics. Temp. Control module was bad. Installed new one I picked up from a GM dealer. Friend in the parts dept. got it for me for $275 for brand new in box. Took about 1/2 hour to install. All back to normal.
This place has one listed for $249.
http://www.parts123.com/PartFrame.asp?ZTM=cadefibc&GHOME=www.corvettecentral.com&TITLE=Corvette_Central
Type in "temperature control" in the search.
Hope this helps.
