Help please
  • Thread starter Thread starter 3tt3vman
3
3tt3vman
I was wondering how I can test the headlight actuator relay on my 85?Motor is fine,ordered stripped gear,now I just need to prevent it from getting chewed up so soon. Does the relay control when the motor stops?I've been looking on sites the better part of the day trying to find some info on this.Thanks alot 3tt3vman
Give me a little time and I will scan and zip up anything I have in my manuel for my 84...the wiring and relays should all be the same.
I need an email address I can send an attachment to.
The motor limit switch is bad....been there...done that. I played with it for 2 months...changed gears and the whole thing....
The armature shaft is spring loaded and allowed to move back and forth. It turns or rotates to move the headlight up or down, once the headlight meets it's stopping point the armature tries to continue moving the headlight, because the headlight can no longer move the worm gear causes the armature to move forward or backward, attached to the shaft is a set of contacts, when the shaft travels enough in one direction it causes the contact on the shaft to hit the contact on the motor housing making the armature stop turning, this is called the limit switch.
When the limit switch quits working the armature continues to try to lift or close the headlight after it hits the stopping point. Something has to give so the gears are made to give after reaching a level of torque before the motor burns out.
So best bet is to replace the motor, else you will continue to eat up gears.
