am I screwed??
When I first started this project on my car a few weeks ago I had to drain the coolant but the radiator draincock was broken and wouldn't open so I had to completely remove it and I bought a replacement unit. I noticed while removing it it was very difficult to take out as if at some point it had been previously removed and put back in wrong but I never looked at the threads closely. I went to put the new draincock in today and before I did I went to use the thread chaser on it to clean it up. I noticed the threads are all screwed up on the radiator. The last person to put the old draincock in obviously had it crossthreaded. I was able to get the thread chaser in without too much trouble at all and once started it went up and down very easily but I can see that the first half of the threads are all messed up but gets better as it goes up.
After using the thread chaser a couple times I tried the new draincock but can't even get it started. I don't want to force it and make a bad situation even worst.
What is my best bet on this problem? I REALLY can't afford to spend $700 on a new radiator this year and I really believe that is is a fairly new repro date-stamped replacement radiator within a couple years at best before I bought the car so it's not old and doesn't need replacing.
Can this thing be saved in any way?
Barry
Barry
