91-Vetteman
Well, I thought yesterday was going to be the big day, put the battery back in and take her for a ride, boy was I bummed out. Over this past winter, I replaced the shift console, auto shift stick, window switches, upper gauge bezel, steering wheel, door locks, AC/heater blower motor, radio, & power antenna. I stuck the battery back in yesterday and had the following problems:
Anyway, I would appreciate any tips or suggestions from you guys to help me troubleshoot problems 1 & 2 above. Thanx !! :confused
- Headlights popped up, light switch is off. My high beams are on, I cannot switch them off. I removed my turn signal / speed control switch over the winter as part of the steering wheel / column restoration.
- Gauges are reading all weird, high and low readings, analog clock not working.
- Horn does not work.
