Help Windows won't work on 94 coupe
  • Thread starter Thread starter eagle6
E
eagle6
My windows on either side won't go up or down. Does anybody have any ideas on what to check and maybe an electrical diagram on the wiring maybe.
_______
1994 Blackrose coupe
Is the window motor running when pressing the switch? I had a weld come undone on the actuator. I would suggest pulling off the door panel, and watch what it is doing? It was a little difficult to diagnose, but then again, my other window was working. So we pulled the door panel on it to see what a perfect working one was doing. After about 10 minutes of watching the broken one, and then the good one, we spotted the broken weld.(Just a dimple) We tack welded it back, good as new now. Saved me some serious bucks.
There's a 30 amp circuit breaker for the windows in the I/P fuse block. It's labeled "M".
