N
ntgarwood
The washer pump on my '72 broke and I replaced it, the copper coil part unraveled. Now my wipers aren't working!! After an hour of racking my brain on it, I found out the fuse was blown. I replaced the fuse but it didn't help. However, that raised concern of where the problem might be. I opened the wiper door with the override switch so the vacuum system is ok. Could it be the relay? The wiper motor? Or any reason because of the new washer pump? I didn't remove any wires from the wiper motor and it worked perfectly before my washer pump broke. Any help would be very much appreciated!
otfl
