R
rpounds
Here's the story. I went for a little cruise today. Took the freeway about 12 miles down to the ocean. I'm on vacation for a couple of weeks and had nothing better to do.
Anyhow, got down there, got off the freeway and everything was fine. Diddled around for about an hour and headed back home. Still, everything is fine. About half way home on the freeway, traffic started to slow, so I hit the brakes. Darn pedal went all the way to the floor with very little stopping power. Of course, this sent a bit of a chill up my spine. I got off at the next off ramp and pulled into a parking lot. I opened the master cylinder to check the brake fluid level. Right up where it should be. Considering that I had some stopping power left, I cautiously made my way home.
I yanked the wheels and looked at the calipers and brake pads. Everything looks normal. The calipers are only about 2 years old, so no leaks and everything else seems to be fine.
I took the cover off the master cylinder again and the fluid in the rear cell looks milky as though it has been aerated. At first I thought that the calipers may have been sucking some air back up into the lines from a rotor running eccentric. I'm going to try to bleed the brakes a little later to see if this may be the case.
However, with the milky look to the fluid in the master cylinder, I'm leaning towards having lost the seals on the primary side.
Any suggestions or thoughts on where to start dianosing?
Sorry for the long post.
Ron
Ron
