The Corvette production disc brake system is an outstanding piece of work, and doesn't need "upgrades" to improve it, unless you're into professional road-racing, or doing repetitive high-G stops from 100mph all day long. There's plenty of swept area, and the rotors have plenty of mass and ventilation for heat dissipation. The unique design characteristic is the fixed calipers and constant-contact pads, which make rotor lateral runout critical to avoid "air-pumping" when the bearing pack loosens up beyond specs or the rotors get warped, or are removed and re-installed without being indexed to their original orientation - the rotors were originally machined while riveted to the hubs and spindles just for this reason, but most converted gas-station discount brake shops don't understand this, as they don't read Shop Manuals and 99% of the modern cars they work on have floating calipers and pads that aren't in constant contact.
The only reason for a Hydroboost system is in a case where the cam is so wild that the engine doesn't produce enough vacuum to operate the power brake booster; that's why GM put Hydroboost systems (or electric vacuum pumps, depending on the model) on the early 80's diesel cars (diesels are unthrottled, so produce very little vacuum).
Ultimate non-ABS braking performance (for a single stop) is determined by the tires, not the brakes - any car's brakes can lock up the wheels, but it's the tire contact patch that determines whether the car will stop in time or not.
About 500 million cars have been built with vacuum power brake boosters, and they're about as reliable as a component can be made; nobody ever intended them to be 100% reliable after 20-30 years of use; people tend to ignore maintenance until something breaks, and how many 30-year-old cars do you see driving around besides Corvettes? Not many. Even precision aircraft components (which cost 10X the price of similar automotive components) are hours-of-operation limited, and have very stringent rebuild/replace requirements based on hours of use, or the airplane isn't allowed to fly. Cars have pretty good reliability statistics for complex mass-produced machines that pretty much get continuous abuse and zero maintenance.
