Help with aluminum gas pedal
Villain
Waldorf, MD
2000 Pewter Hardtop
What's up folks?
I'm sure some of you have swapped out the plastic gas pedal for the aluminum one. How in the hamfat do you get the pin out of the pedal? Is there a C-clip holding it on or is it held in by pressure? Unfortunately you can't really see behind the thing to get a good look.
Any help would be greatly appreciated.
Just replaced mine. Just slide a flathead screwdriver under the pin and pop it out. Goes back in the same way it came out. It's tedious work to put it back in, took me 1/2 an hour scrunched into the well, be patient. Bend the pin a little to get it back in easier, you'll know what I mean when you do it.
Thanks for the heads-up Pac-man. I'll tackle this tonight.
Well, did you get it? I had a time with mine too. You will be glad when it is installed, it looks great. Did you get the dead pedal too? I installed both, they are great additions to my all black vert. Don't forget to wave, -Ed
