Now that I've done about all the simple 'freebie' mods I can do to my car, I'm taking the advice of 'listers and creating a master plan for bigger improvements. However, where to start? What to do? I'd love to hear suggestions from people who've been there/done that regarding the following scenario. I'll try to map things out as specifically as possible.
1. While I'm not afraid to work on the car, I haven't ever done anything to major engine internals (ie, never taken off the heads or replaced a cam or anything). I have all basic tools and some not-so-basic ones, and will buy or borrow anything reasonable. I can (usually) follow complex instructions and I'm not afraid to ask an expert for help or advice if needed.
2. Assume my budget is about $3-3.5k spread over the next three years. This is essentially worst-case; I hope to have more sooner but must work within this amount.
3. The car *must* remain streetable - not as a daily driver, but more than an occasional. Exhaust mods must be wife-tolerable while cruising.
4. The car: high-mileage 86 L98 coupe with 4+3. Non-stock exhaust, but no clue what it is. Done roller rockers, AFPR, all possible mods in front of the TB, 17" wheels, cooling changes (tstat, manual boost fan, lower-temp main fan), centerforce DF clutch. Assume suspension needs no mods. Assume nothing major is going to break and need repair before the three years (yeah, right
5. The goal: 13.3-13.5 at the strip, auto-crossable, streetable, minimal loss to low-end torque if possible. Try not to lose too much fuel economy while doing normal cruising (so 4.09 gearing is OUT). I do want brake upgrades as well.
Any takers? Consider this a challenge...
Or at least a good debate topic.
Gentlemen, start your engines...
Thanks much!
[RICHR]
Thanks much!
[RICHR]
