Now that I've done about all the simple 'freebie' mods I can do to my car, I'm taking the advice of 'listers and creating a master plan for bigger improvements. However, where to start? What to do? I'd love to hear suggestions from people who've been there/done that regarding the following scenario. I'll try to map things out as specifically as possible.
1. While I'm not afraid to work on the car, I haven't ever done anything to major engine internals (ie, never taken off the heads or replaced a cam or anything). I have all basic tools and some not-so-basic ones, and will buy or borrow anything reasonable. I can (usually) follow complex instructions and I'm not afraid to ask an expert for help or advice if needed.
2. Assume my budget is about $3-3.5k spread over the next three years. This is essentially worst-case; I hope to have more sooner but must work within this amount.
3. The car *must* remain streetable - not as a daily driver, but more than an occasional. Exhaust mods must be wife-tolerable while cruising.
4. The car: high-mileage 86 L98 coupe with 4+3. Non-stock exhaust, but no clue what it is. Done roller rockers, AFPR, all possible mods in front of the TB, 17" wheels, cooling changes (tstat, manual boost fan, lower-temp main fan), centerforce DF clutch. Assume suspension needs no mods. Assume nothing major is going to break and need repair before the three years (yeah, right ).
5. The goal: 13.3-13.5 at the strip, auto-crossable, streetable, minimal loss to low-end torque if possible. Try not to lose too much fuel economy while doing normal cruising (so 4.09 gearing is OUT). I do want brake upgrades as well.
Any takers? Consider this a challenge... Or at least a good debate topic.
Gentlemen, start your engines...
Thanks much!
[RICHR]
Thanks much!
[RICHR]
