G
Gman-Vette
Help. I purchesed a 170 Tstat and VHP fan controller from ecklers because my 04 was running a bit hot (240) when ambient temp pushes 100 deg. I installed the Tstat ok, but the connectors on the aftermarket control wire harnes to the fan motor are bigger then the ones on the car. has any one encounterd this? I am connecting to (or trying to) a connector located on drivers side, low under car going to a wire bundle to fan assy. a black and blue conn. not black and orange like the one in kit.:confused
Also does any one know a good burping procedure. I installed the 170 Tstat and car gets hotter faster. I have a manual on disk on order but did not get it yet, so if any one can post a good burping procedure I would be greatfull.
Running hot in CT.
ad
Gman-Vette
Running hot in CT.
Gman-Vette
