B
bobby1
Exactely where does the jacking puck and jack go for raising the front end?
yes that is where the frame is exposed from the body, DO NOT jack on the body!bobby1 said:Thx. So are saying the 2 slotted holes right behind the front tires,only afew inches in from the body?
there are 6 lift points on the C-5 4 are on the outside frame rails where the frame is exposed and have the oval slot that the puck goes into, you put the puck in the slot and turn it.bobby1 said:Disregard the above. I meant that I see one oval slot about a foot in back of the front tire and afew inches next to the body,is that the place for the puck? Thx.
