Help with warning lights
  • Thread starter Thread starter vent69
V
vent69
today i changed the brake pads on the rear and when i got done the BRAKE!, service asr, and the service abs lights came on. i bled the brakes and can not figure out why these lights are on any ideas?
thanx alot,
vent69
You will need to gravity bleed the brakes.
start with the break on the right rear.Don't push on the break peddle.
I think you slipped the sensor,bad news.
So what happens if i slipped the sensor or if gravity bleeding the brakes does not work?
thanx
vent
after you gravity bleed the system and keep the master full of fluid.
Close all the bleader valves.
Start engine and push peddle,see how they feel if light still on then drive the car for a 1/4 mile and see if the light goes off.
If light still on then have someone in the car and open all the bleader valves and with engine running have the person behind the wheel push the break to the floor and hold it their.
Close all the bleader valves and refill fluid and pump on the breaks .
drive car again if light still on then??
You may have to rebuild the master and porportation valve.
Or have the dealer power blead the system.
