C
c4ever
I've had intermittent problems with starting. I've metered the system and these are the results.
Neutral safety switch: purple 7+vt in start pos
purple white trace 7+vt in start pos
red 7+vt in start pos
green 0 vt in start pos.
What is the wiring to bypass this switch if that is the problem.
Solonoid ign. wire in start pos. 0 vt. I assume it is due to the safety switch. Is this correct.
In addition I noticed that the relay I usually hear engage when turning the ign to start is no longer engaging?
Geeeez all I did was install a new starter. Is there a particular fuse or link I can check.
My GM manuals really fall short on this information.
Thanks to all in advance.
Carlo
Carlo
