61 Silver
Hey! Studiog
It is time for an update and pictures on your 61!
Ray
Ray
studiog said:I have to sort out my courtesy light wiring also. It is giving me a bit of a hard time but I guess I'll figure it out.
IH2LOSE said:What problems are you havring?
I am sure you have heard it before but check grounds first. The way I check a ground is with a long test lead conneted to my test light. I connect the long lead to a battery + then when you touch the end of the light probe to a good ground the light lights up.
Battery + is allready at the light waiting for the door to open to make a ground,
IH2LOSE said:Its been a terrible year for back orders espicially on chrome trim parts. Sorry for your delays.
Out of a list of 14 parts needed for the 62 and the 66
9 of the parts were on a 3 to 8 week back order.
Whats happening this year?
And its just not one supplier I treid to order the same list with another vendor and was told the same thing
studiog said:In my case Larry I think I need to take some of the blame as I should know by now that allot of these parts won't be in stock and I need to plan ahead a little better. Only problem for me is that sometimes when I have new parts too long I either lose them or forget I already have them and I order them again
studiog said:Hi Ray & Heaven,
I just got my heater/defrost box in... it was on backorder as were my kick panel metal inserts& grab bar, which are supposedly on the way. Also just received my seat foam which was also on backorder. So now I finally have about 99% of what I need to button up the interior. I have to sort out my courtesy light wiring also. It is giving me a bit of a hard time but I guess I'll figure it out. By the way Ray when you set your parking brake is the indicator light on the cluster suppose to blink? Mine does. The next set of pictures I post will be me finally driving this car on a public road. She ain't been out of the driveway yet and I'm gett'in anxious.![]()
No problem. Good luck with the NCRS v performance check.61 Silver said:Hi! Stuidog
I do not believe that mine even works I have never checked it. I plan on re-working the minor flaws (body work shrinkage, solvent pops and a couple of small stress cracks in the body this winter and then re-spraying the body. I also hope to complete all the items needed for an NCRS performance verification which will include the parking brake. Sorry!
Ray
