EricVonHa
Did you ever notice that if you partially pull back on the high beam stalk that it illuminates the highs and lows at the same time if you hold it in the midway position? Super bright, right!?
Well, what I'd like to do is rewire the C4 headlight system so that any time the high beams are on, so are the lows. I could care less about bulb life. I want it bright!
There's gotta be a way to wire this up!
