T
trochred99
Just installed HID on my vette how do you adjust them?
No matter which you installed, they adjust the same way as stock.
Remove the large round circular cover on the side of the headlight housing and use the adjustment rods to make raise/lower. Just be sure that if they're tight that you lube them as they can break rather easily.
Did you put in just the HID bulbs or go all the way with new projector style lamps?
