J
jrizz1
I just installed a HID light system on my 2000. The headlights raise and turn on when the switch is activated. When the light switch is turned off or the ignition shut off the lights turn off BUT do not lower. I have to manually lower the headlight buckets. Has anyone ran into this problem, or has any suggestions? I removed the HID system and everything now operates normally. Can just changing the bulbs with the added ballast boxes stop the headlight buckets from operating?
