TnTom
When I start the car and let it warm up the temperature will continue to rise until the fan switches on at 240Deg's.(by the instrument gauge).
I have not let it idle until the fan turns off to determine what that temp is.
As I drive the temps goes down and holds at 165. If I stop and idle (say a long light maybe) the temp will start to climb and I have raised the hood to confirm the fan is off and as I suspect the fan is not turning. I drive off and the temp goes down to 165.
What controls when the fan comes on and if I want it to switch on at say 195 degs. how can I make that happen instead of 240? I really want to start cooling before the 240 mark.
) she told this morning that she read somewhere the dealer can adjust a chip and reset the turn on number.
S.T.W.
