ZAKS VETTE
Hello all Zak here,
I have been working on my 92 Lt1 for some time now. Just finished all new brake pads and rotors along with a new master cylinder and new brake fluid. Got new tires put on and cleaned up the rims. This Vette has been neglected for so long I have some list of things to go through before I can really enjoy it.
I took off the throttle body and cleaned it as best as i could and put on new TPS, IAC sensors. New gasket set and air filter.
Now I've turned to my high idle problem and looking through the new shop manual I bought it says to pull any codes, trouble is I don't have a check engine soon light. Manual has me checking things such as fuzes which are ok.
It says to check CKT 19 however following the manual I'm not so sure how to do this? Key off disconnect ABCD plugs on the ECM. Key on check CKT 19 for Voltage? 0 voltage?
Could also be a bulb out.
I'm also checking for vac leaks found one already at the cruse control.
Symptoms are: high idle, hesitation at start the bad stumble at 3000 RPM I can get through that but will stumble again.
Any thoughts from anyone?
Thanks for any suggestions...
