high idle
smf402
New member
california
2002 supercharged LS2 stroked to a 402
i have a 2002 supercharged 402, and all of a sudden the idle is high and jumpy. changed the plugs with no result, is there a way to reset the idle by pulling a fuse?
There are all kinds of reasons why idle speed can become high and unstable.
A common cause of idle problems like you cite is a vacuum leak somewhere downstream of the throttle body.
There is no fuse to pull to correct an idle speed and stability problem.
