krscholz
After replacing the multispeed fan switch on the console, replacing the blower relay and then the resistor and still no high speed fan, I found the solution that I will share with you. It was the in-line fuse that routes from the fan relay located on the passenger side fender well to the firewall. The fuse was not easy to see with all the many years of dust on it. The relay controls the high speed setting on the fan motor. I found this out by short wiring the connectors that attaches to the relay by attaching a wire to two of the connectors on the plug. All positions on the fan switch worked when this was done, so I knew I was getting power except not through the relay. After replacing the fuse that disintegrated in my hands when I opened it up, the high-speed setting worked like it should have. Now, I actually get goose bumps from the cold air from my AC. I hope this info helps. Hover your cursor on the picture to see the detail of where the fuse is.
