fine69
- Joined
- Dec 12, 2004
- Messages
- 975
- Location
- Maryland / D.C.
- Corvette
- '69 Convertible Vette; '72 Z28 Camaro Rally Sport
I replaced my power brake booster after getting home from work last night. It's a genuine GM restoration part, and a tag on it indicated that it had been leak-tested prior to shipping.
I completed it around 9:00 - busted knuckles and all. After installing it, I noticed a somewhat faint hissing sound when the engine is running. However, the hissing stops when depressing the brake pedal. When I push really hard on the pedal and hold it, the RPMs drop slightly. This is opposite the problem I had prior to replacing the power booster - before, the hissing sound would begin when I depressed the brake pedal.
Not sure, but I think the sound is emanating from the booster's check valve - I noted that the valve looks like it comes with a small pin hole on the backside - it was dark, so I'll need to look closely today.
I have to take the car for a test ride, but the brakes seemed to be functioning normal (going up and down the driveway last night).
Is this hissing normal (perhaps I just never noticed it before)?
:confused
:confused
