S
sixty9vette
Fiddling with a used Street Avenger 670. Can't get the secondary float level adjusted. Primary bowl adjustment works fine, but secondary stays way too high (above sight glass). There's no trash on the N&S and tried swapping the primary and seconday N&S to make sure that wasn't the culprit. Also tried another new N&S just to confirm. Float is is good shape, but also tried one off another Holley to make sure that wasn't the culprit. Then I tried a new one. Same thing. Fuel pressure is approx 7psi. My other Holley (4777) works fine at that psi. The metering block is pretty basic, with just provisions for jets. Where to from here? :confused
