Holly Carb Size ?
  • Thread starter Thread starter dbettner
D
dbettner
How do I tell what size and type of Holly I have ,
It is a Holly dual feed 4 Barrel but how do I tell what size and model?
A mechanic told me it was a 750 dual feed double pumper, but that sounds to big for a 350 .
The carb works perfect on my car does not run rich and has great throttle response I also get around 8 to 10 MPG. but the car is very quick and fun to drive so that does not matter.
It is a 1982 with the cross fire replaced with edelbrock intake Mallory ignition and this carb what ever size it is.
Duane, Look on the air horn. On it should be stamped a list number. For instance, on the airhorn of my Holley is stamped 4777 which translate to a 650 CFM 4160 series double pumper. Post the number and I or someone else can cross reference it for you. And yes, double pumpers do have great throttle response.:D Charles
Like 72Mako said, get the part number from the driver's side of the choke horn. Then search Internet; Google is your friend. Holley information is everywhere. :D
