gmjunkie
Next, I have had no problems with the carburetor before, and I'm not sure that I have problems now.
Oh believe me,if it's a "HOLLEY" at some point there are going to be problems!!~!
I have the quick fuel BD750 on a 500hp 363 Ford Racing Stroker crate engine and it is the best carb I have used yet. However, I highly doubt a 750cfm would be appropriate for any 327.
Unusual Activity Detected - Free Shipping on Orders Over $99 at Summit Racing
I have used the Quick fuel SL600(air cleaner must be modified) and the quick fuel BD-1957 on 327 and stock 427/390 engines with great success. The BD-1957 is almost a direct bolt on replacement for the 2818-1. Not trying to get off topic, but when set up properly, quick fuel carburetors really can't be beat.
Not sure why it says unusual activity detected. Those are links to the carburetors on summit racings site.
The, idle and idle transfer circuits in double-pumpers are calibrated for racing engines with "big" camshafts and, thus, when bolted on a street engine or mild high-performance street engine which generate big vacuum signals, they'll run rich. You cannot compensate for that with jetting because when those circuits are supllying most of the fuel, the main circuit is barely working. Also the proportion of fuel flow though the main circuit and the power enrichment circuit is skewed towards race engines. Restricting the idle feed restrictions and changing the proportion of fuel flow though main and PE circuts are just two of the mods you have to make to run a DP on the street.Why would a double pumper run rich on the street? Is the secondary accel pump discharged like a fuel injector nozzle even though the secondary butterflies aren't being opened?
The Performer is a "medium-rise" at best.The Edelbrock Performer is higher than the old GM cast iron intakes, about 1/4" shorter than the Winters aluminum intakes used between 1962-1967. I'm not sure what constitutes a "high rise" intake? Maybe anything taller than the cast iron ones? Can you call the Performer an "almost high rise"? The Performer RPM is at least 1/2" taller than the 1962-67 Winters intakes and about 1/4" taller than the LT1 intake, so that might be called a "super high rise" intake.
Neither the Z/28, 396/375, 396/425 or the "HO 427s" came from GM with double-pumpers. They all had dual-feed, vacuum-secondary Holleys. The only Chevrolet engines to come stock with double-pumpers were '69 second-design L88s and ZL1s, also, in 69, only, Z/28 302s did have a DSO cross-ram intake manifold that mounted two Holley DPs. The same 2x4 X-ram was available the year before but, in '68, both carbs were an odd mech. secondary, single-accel. pump unit–which must have sucked much to drive.Hib,
I've heard DPs are poor street carburetors. I guess I'm dating myself. However, back in the day everything from a Z28's 302, 396-375, the Corvette 396-425, and the HO 427s came with a DP Holley.
Again, that's not correct.Back then, a DP Holley is what they came with from the factory and we drove them on the streets.
With all due respect...yes you did. You just didn't know it at the time. Also, everyone's concept of "drivability" varies quite widely as well as differing by period.I didn't have any issues running them; even center shooters on a tunnel ram. Or the gear drives on the choke side.
Obviously, it's a "modern" thing as WBO2Ses priced for DIYs did not exist until fairly recently. Read this story elsewhere on the CAC about tuning a DP for the street. That could not have done without a wideband.By your mention of a wide band O2 sensor; is it modern engines that have issues? I do know, back in the day we sure didn't. Is this a modern thing?
I have a Quick Fuel 750 dual inlet race carb on my 327. Doesn't have a choke horn. One pump cold and the engine starts and runs immediately with a turn of the key (say, 1/4 of one crank), with some feathering of the throttle for the first 20 seconds until things warm a tad.
Plugs run perfect color, no fuel smell, no rich exhaust. WOT from a dead stop in 1st gear and the engine roars and the tires go up in smoke and revs hit the limiter immediately. No hesitation, no bog. Mash to WOT in 5th gear @ 2000 RPM and the engine pulls smoothly and steadily with zero hesitation.
What's not streetable about that? Plus 20 plus MPG @ 75 MPH with the 5 speed.
If a carb is properly tuned with suitable jet, power valve, and air bleed sizes, then all will be well. This issue about mechanical secondaries not being streetable is hogwash.
As mentioned above, SIZE is important. A mild 327 or 350 will be very happy with a 600-650 single feed carb because of the small throttle bores. A 750, single or dual feed can be appropriate as well, because the 750 uses downleg boosters, which make it more sensitive and responsive to low manifold vacuum than a 600-650 which use straight leg boosters.
Looks like about 425-hp SAE at 6600 rpm or right at 500-hp SAE at the crank. That's a pretty stout 327, for sure.
Curious....if peak power is 6600 why the 7750 rpm rev limiter...are you planning additional mods? What kind of valvetrain hardware do you have such that the valvetrain is stable at 7700?
Finally, the 20-mph figure is outstanding. I'm interested to know about the car's weight, trans and axle ratio.
