74bigblock
Hey all! I'm working on my pipes and headers. Keep in mind this is a Big Block 74.
Drivers side header is mounted... and one of the down tubes is just touching my fender before it goes into the collector.
Passenger side is just touching the frame rail as they go across.
I need to devise a way to get 1/8 to 1/4 in clearance between each. My two ideas are as follows:
1)Drop Trans mount down a bit wich will pivot engine down causing headers to drop that little bit I need. Don't see any concerns here, and will prob improve driveline angles ta boot.
2) Sloid (Sloid...yes I am a putz. I meant SOLID!) Engine mounts relocating just a tad. Concern here is clearing oil pan.
What do you think??
Thanks,
Dave
What do you think??
Thanks,
Dave
