tonyponykay
- Joined
- Mar 14, 2009
- Messages
- 60
- Location
- Baltimore, MD
- Corvette
- 1980 maroon, 1987 vert yellow/black "bumblebee"
it doesn't say on my AIM or my tech manual CD how to actually attach the horn button and the collar that goes around the button to the retainer that clips into the circular collar on the steering column.
there are three little studs on the collar that line everything up, but it did not come with screws or anything and the whole assembly was taped together with masking tape in two spots.
Does anybody know the way to keep the horn button and collar attached to the retainer?
do you spread the studs out with an awl/ by beating out the outer edges of the studs to hold the assembly together?
If one glued it, the button wouldn't go down to make contact so I's very perplexed as to how to get it to stay together. without some method, the button and collar just fall off the retainer ring.
:eyerole:W;help
thanks
tony
:eyerole:W;help
thanks
tony
adhow to attach button and collar to retainer, diagram just shows parts on pg 498, but no clues on how the assembly stays together, reaaallly frustrated,
