Horn Relay Location
  • Thread starter Thread starter 69redvette
6
69redvette
'77 Horn Relay Location
Anyone know where the horn relay is on a '77? Any help would be appreciated.
Not for sure but in most c3s they are under the dash near the steering column
On my '72, it is on the DS fender well. It has several "hots" going to it as well as a green wire that goes to the horn and a black ground that goes to the column.
CS
On my 71 it was on the driverside, on the rear of the fenderwell. It set right under the fender lip on the back of the innerfender. robert
according to my '77 assembly manual it should be plugged into the harness a few inches above the fuse panel. It is rectangular in shape.
