Help! Horn stuck on
cheftl13
CT
1981 DARK RED METALLIC
My horn was got stuck the other day, had to pull off the button, and would not stop, finally the fuse blew. Put a new fuse in and horn kept going till it blew again.. any thoughts, Im thinking the relay. if so, where in the hell is it???:mad
there is a relay(?)down near the fuse panel I believe it is yellow.
pull it out and it will disable the horn.
Could be the relay. Could also be the wiring inside the column is shorted.
