Horn will not cut off
abvpar
New member
Glenn Dale, MD
2003 ZO6
Have an 03 ZO6. Horn came on and would not cut off when sitting in garage. Checked relay by swapping with another. Replaced battery as it had low voltage. Each time I believe I have found the remedy it randomly comes on again. Sometimes it seems it may be in conjunction will a door opening or closing or change in power consumption but not always. Car had been sitting for a day or two in the garage and had not been subjected to any elements or unusually cold or heat. Any suggestions?
Thanks,
John
Thanks,
John
Don't have an answer for ya but welcome to the forum. Noticed you are from Glenn Dale, grew up there many moons ago. Hopefully someone will come along with some suggestions for ya.
abvpar, first off a welcome is in order. :w As you have already seen, we have a lot of very helpful people here. :thumb I have moved your post to the C5 section where it will get more appropriate responses. I am assuming that you just clicked the wrong generation area when you posted. Good luck with the fix of your horn.
