The tire size for an 18" wheel would be different... you are looking at a smaller sidewall (the second number) tire sizes break down like this (width)/(sidewall)/(rim size) On an 18" wheel, a 50 sidewall would be like a truck tire... you need to look for a 40 sidewall (or a bit less, say as low as a 30) You will find many options of tires then... on a 9.5 inch wheel, you can go to 285/40 easily, the most common size would be 275/40. 255/45 or 255/50 would be for a smaller wheel, say 8.5 inches wide, and the 50 series tire would be more popular on a 16 inch wheel, 45 series on a 17 inch... The later C4's have (mostly) 17" x 8.5 up front, and 17 x 9.5 in the rear, with 255/45/17 and 285/40/17 tires respectively.... Z51 cars and C4's from 88-92 with the 17" wheel had 275/40's on 17 x 9.5 wheels front and back. The 18" wheel on the rear of the C5 has 275/40/18 tires
