Hrtbeat1
87blackroxi said:But my concern is it's a daily driver. Would 3.54's be ok for daily use? Like on the highway, would I just have higher rpm's? And last Q is what is the average price for the gear swap?
I've always gone for excess. I swapped the whole rear for a D44 with 3.45's every thing bolted right up, except the drive shaft and C-Beam. I knew about this before hand and was prepared. I picked up a C-Beam and driveshaft from a manual from Dino's Corvette for $250. The rear I got off Ebay .... actually from a member here ... for a little over $2K with shipping. I was looking for one with 3.33's being a somewhat daily driver. Got out bid a couple of days earlier. Actually I'm glad it happened. With the 3.45's, cruising at 75 - 80 I'm spinning around 2400 - 2500 RPM in OD. My torque converter is a 2200 and I think the 3.33's would have been closer to having it lock/unlock at cruising speed. Before I might spin a tire from a dead stop, but now from a roll I can
shift to second and still
this is pretty much at will from stop to about around 10 MPH. To keep from spinning during a launch I try and keep the RPM's around 2000 or below, actually I my brake torque is between 1500 - 1750, not much pedal at all. I'm running Firestone SZ-50's that hook pretty good when warm but they take a LOT of heat to actually warm up. These are great for a "spirited" daily driver bad thing is they don't make them anymore.I would spend the $300 on a set of Drag Radials. I bet they get you to the 13's. I've heard good things about just about every brand made, so I guess its "pick your brand." None of the Drag Radials will give you long life so it would be best to have these mounted on a seperate set of wheels.
My setup is pretty much the same as yours. I've done the AIR thing and the TB bypass (do it ... very easy ... can be done for $5 or less). I have done some tuning to the chip in mine. I haven't run mine at the track yet, according to a G-tech I was getting 60ft times in the 2.1 - 2.0 range before the gear swap. Now I'm right around 1.7 - 1.9 depending on wheel spin. I really need to go to the track ... its only about 7 miles away ... every Wednesday.
AdvancedAutoCC I've heard that for every .1 you gain in the 1/4 it equates to a 10 HP gain. Does this sound accurate?
