How do I get the front bumper off?
SoLow
Atlanta Ga
87 dark red coupe 96 Pro Street Project
Does anyone have the procedure on how to remove the front bumper on an 87 coupe? It took about 4 hours to remove the rear with the help of a person with small arms:eyerole
Its possible to get a 1/4 inch drive socket and extention along with an open end wrench in there without taking the hood off. But if you have a friend to help, taking the hood off isn't that hard either.
I have to repair a hole in the hood also and would like to avoid taking it off if possable
mhmm
You don't want to take that hood off if you don't have to.....only as a last resort in my opinion. I have done it many times, and every time I do, I wish I hadn't. It's pretty tricky to get it lined up right, and heavy as a H***
If you pop the hood, look between the crack of the hood and the bumper. There should be 8 bolts that go through a metal bracket into the bumper. Need a small wrench to get to them. Then there are 6 bolts down at the botom of the bumper, (inside the engine compartment, near the fuel vapor canaster) There are 6 on each side. They also go through a metal bracket kinda thing. Then remove the 4 tork head bolts on each side that hold the bumper to the wheel well. There may also be a few on the bottom side of the bumper but I'm not sure. Then the pumper should pull off. Gotta work it a bit.
good luck
haha
HAHA most people can't figure it out. good job, you win a shiny new Dime
But.... As a rule, how long will a so-called 'Eight Day Clock' run without winding?
