Question: How do I tell if my alternator is failing
RevPat
Villa Rica, Ga
I have a 1981 Corvette. Recently the battery light came on at a very low glow while idling and a brighter glow while driving at about 40 miles per hour. I was told the alternator was failing and should be replaced? Is this correct or is it another issue. recently had starter replaced battery is good
There is a good chance that the "diode trio" in the alternator is bad. It is pretty inexpensive and easy to change, while apart changing the brushes would make sense too.
Thank you for your advice to both of you
