S
studiog
Hi all! I am getting ready to strip my 61 body and I just wanted to make one last effort to see if there is a way to tell what color it was originally. The present color is badly painted white body/rough black interior. I have tried to scrape with a coin behind the passenger seat to reveal the wax pencil color marking but nothing could be seen. I had a resto. Vette body man check there too but to no avail. The body is totally bare including the dash pad which appears to be white underneath but the Vette body guy said that he thought they were all white or light colored in that area. I have looked in the trunk floor and side walls & see red as the bottom most color. The inside trunk lid is white among other colors including red. In the gas tank compartment again I see areas that look white but I can see fiberglass through some of it. In the area near where the outboard seatbelts would attach I can see shinny red areas where it looks like other paint that had been over it had worn off. Up under the dash looking through from above down through the radio speaker hole I see some flat looking red. The upper steering column also is red underneath the black. Behind the clock/heating control console mounting area some red is revealed. The kick panels are red on both sides of both panels. The inside of the cluster housing has traces of red. The interior floor doesn't seem to have any color just a gray fiberglass look. The area under where the windshield frame mounts to the body doesn't have much color but I would say it appears slightly white, no appearance of red at all. Have I missed somewhere that might definitively tell me what color the body was. Right now I would only guess it was originally red interior/ white body. Any help appreciated as usual. Thanks.
