Problems as of now
no no no I meant differently mike, sorry about that.
What i mean was if there was a lot of white smoke there would be a problem. There is only a bit. I have not had a chance to check it out yet but I will after tommorow.
She was really abused in her previous life and I am trying to piece her back together. At the moment I don't have the money to finish the job right away but I would do some of the little things first.
As far as mechanical problems are concerned here are the symptoms keep in mind that the differential has been rebuilt with a 3.08 gear (for fuel economy and drivability, she origanilly had 3.48). New fiberglass spring, new clutch, engine rebuild (355 with 2.02/1.60 valves, .48" lift with 282 degrees duration, single plane manifold, holley avenger carb, headers with 2 1/2" true dual exhaust).
Anyways back to the problems.
1. when in gear i can here a tapping sound coming from the right side of the engine and corresponds to rpm. I am thinking i am going to have to adjust the valves. Do you think thats what it is?
Could it be something else?
2. I can here the differential after i have driven it for a while. A whining sound. Its not really loud but its noticable. I am also keeping in mind that the differential is right behind me. I am hoping thats its just cause its breakin it but if it has to be adjusted so be it.
3. Smoke coming out of left side of engine. Was happening with the previous carb (quadrajet) so i don't know if its the carb or something else. I have not had a chance to hook up a vaccuum gauge to check it out and fine tune the carb.
4. I sound coming from the right rear tire. I don't even have a clue as to what it could be.
I think these are the immediate problems that have to be addressed right away.
Any suggestions on what they could be, or whats causing the problem?
Any help appreciated!
sscam69
