norvalwilhelm
am finally installing the new 14 inch front rotors. They have been machined as a unit and I know that all surfaces are true to each other.
The next step was installing the rotor on the hub. It is going to be going on and then marking one stud, torque the 5 lug nuts and then with a dial indicator check runout. I use a felt pen and mark on the hat the runnout with the rotor installed in that position, take it back apart, move one set of holes clockwise and do it all over agian remarking the runout with the rotor in that position.
I do this 5 times per side and try to get the least runout. Well without shims all positions show .008 runout?? This must be the hub runout??
I checked bearing play and found .004, this is the front remember.
I will take the .004 out of the bearing tonight and retry but this is the question.
I want to true the hubs themselves. I have the lathe and the dial indicators.
How do you set up something like that that rides on the bearings, not the outer housing. How could you do it???
How do I get my hubs faces trued??
With 14 inch rotors instead of 11 3/4 it really shows up. The calipers don't know the difference so any runout affects them regardless of the distance.
