I'm pretty sure I've got too much pressure under the passenger-side valve cover because even with my new oil cap, I'm still pushing out oil at high RPMs (now it's coming from around the breather hose and/or the valve cover). It was suggested to me that I run either a K&N filter breather and close the port on the throttle body, or perhaps enlarge the line to the TB (which might be difficult if that port is the narrowest part). I'm also thinking that I've got a smaller-than-stock hose on the PCV valve on the driver's side...
Is this all connected, the PCV and the passenger breather? If I use a breather filter, will that mess with the PCV setup? Will it make a mess under the hood, or are they (as I was told) a one-way valve as well? What is the direction of travel for the air in the crankcase? plenum->PCV->crank case-> TB? Or the other way around? If I run larger-ID tubing, will that help? Is Jupiter aligned with Mars? Does your chewing gum lose its flavor on the bedpost overnight?
Thanks.
[RICHR]
Thanks.
[RICHR]
