Twin_Turbo said:
Okay, someone explain and convince me what the VB&P suspension does to improve the stock suspension? Does it fix problems that the stock suspension have???
I'lll wait for the responses and then I'll gladly give a rundown on what's wrong with the stock suspension and how the VB&P stuff does not fix any of it
B.T.W. Have you driven a C5 and cmpared it to the VB&P setup???
YES!
TT, i am curious to your responce and info. it all depends on what VB&P kit/product you are refering to. i'll agree that replacement coil springs or composite mono-mount springs do nothing to improve the handling. but i disagree with the statement of VB&P does nothing to help the C3's.
let's talk rear-end. stock camber rods are JUNK!! they can't hold an alignment setting, any real power applied and they pull into another position and stay leaving you with tipped in rear tires. they also allow camber "swing" through the travel of the rear tires/suspension. by this, i mean with suspension fully unloaded the tire's tops lean out (looking from rear of car) compared to the bottom, and fully compressed the tops lean in compared to the bottom. this "arc" swing in camber upsets the geometry of the car not to mention take valuable rubber off the road. surface area, aka contact patch, provides traction allowing the whole handling thing to come into play. no traction, no handling. VB&P smart struts replace stock and mount differently. they mount so that the strut and half shaft are parallel. this makes the rear tire travel straight up and down and keep maximum tire on the ground. another benefit is the tie-rod style adjuster. they don't get pulled out of alignment. rear sway bar, most cars never had them, most need them! stock single central mount springs actually rock like a tee-der-todder at the differential. VB&P dual mount eliminates this problem. it is like getting a sway bar without having to install one, then add the sway and bam, no more rear body roll.
alright the front. stock sway bar is a wet noodle, to small for a heavy car. upgrade, many manufacturers make bigger ones. stock a-arms, not bad, heavy but not bad. new a-arms are lighter and stronger, i'll get to the lighter thing later. coil springs work and have so since 1850, upgrade time. coils are heavy and not easily adjustable. your stuck with a spring rate and limited ride height adjustments. the spring pressure is transmitted into the frame in a way that tries to twist the frame rails, hence the transverse stabilizer bars running between the upper a-arms under the hood that a very common on auto-cross Vettes. this force increases frame flex slightly, frame flex = poor handling again. VB&P transmitts the forces into the bottom of the frame under the engine cross member, more of a lifting force instead of a lifting and twisting force. the front dual mount works similarly as described about the rear. there are slight improvements in steering geometry, but hardly worth mentioning. after all the other benefits you won't notice the caster and camber refinements.
now the rest of the rant, sorry this so long fellas!! unsprung weight is bad. anytime you can get rid of it, do it!!!! big rim o-ring tires and aluminum wheels help a bunch. so does dropping a couple pounds off the a-arms and springs. improves the responce time of the acting wheel = improves handling!! dropping weight from car, this is great!! the better your surface area of tire to weight ratio, the higher g-forces are attainable, just look to the Mazda RX7 for an example. light and big treads, possibly the best handling production car, still debatable but impressive.
poly bushing kits instead of squishy rubber that rots away and gives that Cadillac feel, i'll leave that one alone. VB&P comes with all poly for every joint.
finally for now, the ability to adjust your suspension to fit your needs!!! VB&P allows the adjustment of ride height, bonus! it allows the adjustment of spring rate, another bonus!! it allows the independant adjustment of either, without affecting the other, huge bonus!!! adjustments can be made to all four tires in less than half and hour with hand tools and no parts to change, SUPER BONUS!!!!
so in conclusion, i sound like an info-mercial on late night TV.
SORRY. but i am just a very satisfied customer with a very good product. i know my $.02 is looking more like a Ben Franklin note, sorry but it is my humble opinion, TT i am looking forward to hearing your ideas on the subject, Brian
