hogwild
New member
What kind of HP gains will I see with a better exhaust,CAI, and a good dyno tune? Is it worth the effort or just enjoy the C6 as is?:W
From my own experience; I have headers, Corsa mufflers, tune: It dynoed at 380 RWHP.What kind of HP gains will I see with a better exhaust,CAI, and a good dyno tune? Is it worth the effort or just enjoy the C6 as is?:W
I might be wrong, but I think the rev limiter would prevent an engine from blowing.I was afraid of breaking something or blowing up my engine. I don't know about you, but I cannot afford to replace an engine if I start adding turbos and super chargers to it. But it would be sweet to have!!!:cool
Probably right, but I would think by adding turbos and chargers that you would have to change your computer settings which would do away with the rev limiter. Not sure but you are probably right. :coolI might be wrong, but I think the rev limiter would prevent an engine from blowing.
If you are asking, then I'd say probably no. Let's say you get another 30hp. (Best case scenario.) That's going to put you at around 380 or so. Right now you are 350-355 give or take. Here comes the deciding factor~What kind of HP gains will I see with a better exhaust,CAI, and a good dyno tune? Is it worth the effort or just enjoy the C6 as is?:W
, Can you quote me a general price for the 4:10 gearsOn my 02, I did K&N filter and exhaust. It was Ok with some difference.
But.......when I installed 4.10 rear axle ratios replacing the 3.42's, it was amazing. 5th gear became a fun gear on the highway and 6th gear has some pull out there also. 1st thru 4th gears are like you added 100 HP. WOW and WOW. The best performance enhancement to date. It's about 2K to get the gears done, but everything else is untouched and factory reliable. Everybody wants to see under the hood and are baffled when they see nothing different.
AintQik is right on the button with doing gears. I just got my new '07 so I haven't looked into who offers the 4.10 gears for C6's yet. I'll still do the exhaust and K&N though. I need a bit more noise than stock.
I'll do the same with my new '07. It makes for quite a sleeper!
Chuck M
