Jack
- Joined
- Dec 27, 2000
- Messages
- 1,825
- Location
- Florence, SC (Timmonsville SC)
- Corvette
- 71 War Bonnet Yellow VERT 71 BH Blue CPE (SOLD)
Hey boys & girls:
I'm thinking (hehe mistake one) of COMPLETELY blocking off the hot air crossover through bottom of my 71's 388 sb INTAKE to gain a cooler charge & small performance boost ... what do you think? Winter's fairly mild here in SC. I have a low-rise Non-EGR Weiand aluminum 8004 intake (I'm guessin' it shouldn't matter whether Fe or Al?) and a Qjet on iron GM heads (intake & both heads have the x-over ports). I know other intakes/heads come with no x-over ... also intake gaskets available with no x-over hole. My universal intake gasket set also came w/ two metal inserts. The inserts can be used or not ... they'll restrict flow through a round hole about 1/2" dia. Gasket Instructions say use on one side for year this ... other side for year that etc. I can get other gaskets w/ no x-over hole if that's all there is to it ... dunno if it wouldn't just burn through over time though? I'm also capable of a bit of fabrication ... though I'm not fibbin' here! So, should I block off ... if so How ... and then should it be partial or complete? What's a simple, reversible & reliable way to block it off? For now, heads & intake are off block. Thanks in advance fer yer thoughts on this!
JACK:gap
JACK:gap
