** How to Check Alternator???
95ZR1#418
Missoula, Montana USA
95ZR1#418, 88Z51Coupe, 69L46Coupe
Hi All....
I have a goofy wire problem out of nowhere. I will clean battery terminals(batt has full charge)but want to check alternator. How do you check the alt while on the car, I probably have the tools just need to know how?
Thanks Bob
Connect a Voltmeter across the Alt. output terminal and case.
With the motor running the Voltmeter should read about 14.7 Volts.
Turn everything on, i.e., Lights, A/C, radio, rear window defogger, wipers, etc.
The voltage should not drop much below 13.8 volts.
:w
