T
t78
Took the EGR off last night because I noticed that the valve was frozen (Hopefully this is my idle problem... trying everything....)
I was able to free it up some with WD40 and some other penetrating fluid. How would I check this thing to see if it still works? (before I put it back on) Should the valve stay up if I push it in and hold my finger over the vacuum hose connector and then let go of the valve?
Also, would it benefit to just block this thing off?
Thanks,
t78
Thanks,
t78
