Video: How To Do A GM Certified Oil Change on a 2020 Corvette
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
Here is a behind the scenes look at what your 2020 C8 Corvette will go through when it gets its oil changed. Who knew you had to run the engine at idle for 20 seconds to get all the oil back in the dry sump oil reservoir before beginning the procedure! After you’re finished, you […]Source
More...
