D
Dave1998
I would like to dremel my stock air filter lid, but dont want to unbolt any unnecessary parts to get this lid off. Can anyone explain the process to me?
thanks. Dave
thanks. Dave
A little WD40 on the grommets helped me. Hope the @#$% plastic clamps don't break for you like one of mine did when you replace the lid.Dave1998 said:Thanks to both for the tips. If anyone else has done this I would like to hear from them as well
Dave
04cmnthru said:Could be w/re to hairspray - never thought about the residue issue. My concern was using a petroleum product on rubber items - largely from cautions found with "O" ring seals. It may be an unfounded concern in this case. A friend suggested using a very thin film of waterless hand cleaner as an alternative. Well, as they say, more than one way to skin a cat. Hopefully, Dave 1998 found this helpful.
I used a dremel tool with high speed cutting tool. It doesn't generate shavings like a saw would and it's a more precise tool. I just used some painter's edging tape around the painted surface just in case I got a bit sloppy and touched the paint. I cut with the black shrouds in place and left the fogs in place. Then vacuumed the inside. I had to cut the mounting hole off the screens to get a flush fit, but I wasn't using them anyway. The whole process took less than 30 minutes. They've been on 2 years now.04cmnthru said:Hi CSDMagRed01- Thanks for the tip. Question for you - I have Z06 screens to install but want to make them functional. Any tips on cutting the solid plastic fog light shrouds? What did you use to cut them? Did you leave them on the car? Did you remove the plastic pan under the car so that shavings would fall out?
By the way, have many of the same mods you have - but I have the Z06 Ti exhaust too. Its a great compromise over stock and the tips look great.
I went the Frost King route last year, putting it between the outer wheel wells and the inner. Stuffed the empty area around the fuel filler with fiberglass batting, etc. I was still not satisfied. I just installed Second Skin de-amplifier and a layer of Quiet Car liquid both on the inside under the carpet. A very significant improvement. I plan to do the same treatment to the front wheel wells when I go in to install the side fender screens.04cmnthru said:Thanks. Appreciate the info and will use the Dremel tool. Look forward to your updates on your web site. On the sound deadening, did you go the Frost King route?
