R
roxeye1
A chance to share your goods! If I only had between $2000 & $3000 bucks ready to be blown on the most power possible for my C5 , what is YOUR recipe to achieving this objective - sans nitro.
Even though you said "nitro" (nitro-methane), I assume you meant sans "nitrous" (nitrous oxide)? If so, this is a tough question to answer. $2-3K is not enough for h/c or an entry-level blower. The money will go especially quick if you are paying labor too.
In no particular order, here are some things you could look into:
GL!
- Have your stock heads milled and ported (porting will improve flow; milling will increase compression ratio)
- Long tube headers
- High-ratio roller rockers
- Replace stock air box w/ something freerer flowing
- Full dyno and/or street tune
GL!
- Long tube headers
BTW, the example I gave above is just that, an example. REAL HP gains are not cheap for this car.
The real question you have to ask yourself is:"what are my intended uses for my Vette?"
Drag, autocross, recreation, bragging rights, daily driver, etc.
For $2k-3k you can upgrade your exhaust and either get a Z06 air box lid ($50), drill holes in the OEM lid (free), upgrade to a performance filter system (Blackwing, dual-cone, Halltech, etc.). The exhaust (in theory) might buy you 0-8 HP (if only getting a catback). The filter might buy 5 HP more (maybe).
I'll take a 350HP beast that can smoke 99% of the cars it comes across (and built in AmericaYa know, you're right. Do i really need a 450 HP motor in my car - just to pick my son up from baseball practice and run errands? I think a throatier exhaust along with your other suggestions will suffice. It's pratical. And the ego will just have to be content with the puny gains!![]()
You dont need to spend 8 to 9 grand for horsepower to have fun. I have had a few very powerful cars and I can tell you it will cost you lots of money and be less reliable. You want to upgrade your power output a bit so you can have an advantage over stock. May cars have had superchargers, nitrous and turbos. My fastest car had 1200 hp on the dyno. I also have a 7 second NHRA license which I received at the Frank Hawley drag racing school in Gainesville. I will tell you what I did to improve my 2000 a/4 coupe. First I purchased a Predator Diablo programmer and loaded the performance tune. I made some minor changes suggested by the moderator Mike Mercury and felt the car more responsive just with this. I then bought the slp power flo cat back system and also felt much less restriction on the exhaust side along with more seat of the pants feel plus awesome looks and sound. My last mode is the vararam b2 intake with new air bridge/coupler/velocity stack.... the whole kit and it along with my two other mods has made a nice difference in my performance output. I smoke the tires easily and my tranny shifts firmly. I know this is about a 35 to 45 hp upgrade. I would not waste my money on a supercharger or expensive engine head/cam etc.. modifications unless you are a hardcore street racer. I have never been a proponent of nitrous oxide but I have learned that it is the best bang for the buck by far!!!! I plan to add a wet nitrous system in about 6 months that will add about 150 horsepower on special occasions. It is completely safe if used prudently. Technology had come a long way and nitrous systems do offer a very high level of performance without the expense and without internal modifications. You gas mileage will remain the same and all things will work as the factory intended because your mods are not permanent. Nitrous will give you that edge when you need it!! With my minor mods and my nitrous system I expect at least 500+ horsepower when used. your 3000 bucks should be enough for these mods and you wont regret them. good luck, edram
A chance to share your goods! If I only had between $2000 & $3000 bucks ready to be blown on the most power possible for my C5 , what is YOUR recipe to achieving this objective - sans nitro.![]()
Not knowing exactly what your Vette has for a tranny and rear end gears......forget the "horsepower" idea and invest your money in a different set of rear end gears and/or a higher stall torque convertor if it is an automatic.
Doing so will not compromise the internal integrity of the motor and potentially shorten its long-term reliablilty, but will provide you with a dramatically noticeable difference in how the Vette accelerates.
A higher stall converter is big bucks to install and purchase. True it will give you a more agressive launch but you will blow off you tires and lose a match and rear gears will certainly cut your quarter mile times with a trade off in top end speed. just depends what a person wants. I know people with just a improved induction system and improved exhaust and timing with a 100 hp nitrous shot in the high elevens with stock tranny and rear end 273 ratio. food for thought. edram454
Those three plus high-flow cats = $3k and yields a very nice increase in real HP.
- Long tube headers
- Full dyno tune
Me too but it seems to blow the budget :eyerole
