Hurst shifter-Back up light switch. Help
69MyWay
Auburndale, Florida
1969 Killer Shark
Does anybody know how the back up light switch gets put back in, or hooked up on the Muncie four speed with the Hurst shifter conversion?
If memory serves ( On my 73 )
There is are two wires that goes to the REV switch
Pink & Light green
Pink= Ign power
Lt green= run to rev lights on a 2 pin connector.
This is a single connector thru the firewall and down to the tranny ( Pass side ).
There is a flange which mounts to the Transmission side cover plate. The flange mounts the switch and the switch gets actuated from a piece of wire ( read carb linkage bent wire ) going to the reverse lever on the tranny.
So it shouldn't matter what linkage you have, the connection is from the tranny to the mounted switch.
Mike
