Can someone let me know their thoughts on this.
1996 6 speed. Bought the car with known clutch/trans probs.
Need to pump up the peddle a bit to get enough pressure to shift gears. Seems to be getting worse. I looked no obvious leaks, clutch master is full.
I tried bleeding the system by opening up the bleeder screw on the slave letting some fluid run threw then closed it up and pumped for a long time getting as many small bubbles out by watching the reservoir and pumping peddle. Well i have no pressure now.
